New Motor Need Help
8650mustang
sounds like you have an air leak causing a super lean condition unless the pipe was so full of excess oil that it started to burn. I'd check the carb boots and intake tract very closely for ANY even tiny air leaks. Spraying WD40 on all the seems at carbs and boots and reed blocks etc will make it run oddly and pinpoint the leak.
Pull the left carb and take the pilot jet out... make sure nothing is plugging it up. Check the air screws to see if they are equal. Do you still have the TORS boxes on top of the carbs? If you do make sure the idle adjust screws are turned out the same amount.
