Ahh This On My Carb
If I understand you right you are talking about the choke tube. It (the carb bowl with the brass tube in it) should go on the carb with the choke pull handle. If you swap your bowls you will find your choke does nothing. On a side note both of my bowls have the tube in them but my last machine didn't - weird
Both bowls have a brass tube, this is the overflow tube.
The carb with the choke lever has a brass tube extending down from the body into the bowl where as the other carb doesn't. If you look at the bowls you will see the orifice where this tube will slide into. One bowl will have the bottom of the orifice drilled out to the main fuel area where the otherone will not.
It is important to match the bowl with the drilled orifice to the carb with the chock lever and brass tube for the choke to operate.
