More Compression Or Advanced Timing?
Wallrat
I understand the principles involved in each and that you can only go so far with either method before you can't run pump gas anymore. My question is, what kind of power difference would you get with each? For me being at sea level, I can only go down to 20cc domes or so with a +4 advance before I might run into detonation problems. So would it be better to keep the stock timing and get smaller domes?
I gained 2 hp across the whole curve w/ the +4 timing. I don't think you could gain that going from 21cc to 20cc...though I could be wrong....Good question..
