jasonsb Posted January 26, 2004 Report Share Posted January 26, 2004 Thanks for all the good advice. However, going to a 9 or 10 paddle is not an option right now...I already bought them. I assumed that going down a tooth in the front would help in the sand and hill climbing. Before I changed paddles , I used to run v-paddles (sand sharks) and it would struggle up big hills. I had to stay in 3rd or 4th...using stock gearing 14-41. I bought a 13 tooth but haven't put it on yet. I weigh 180 and want the bike to hit 5th gear going up hills. How much air pressure will be good in the sand for my weight? Quote Link to comment Share on other sites More sharing options...
909 Posted January 27, 2004 Report Share Posted January 27, 2004 Thanks for all the good advice. However, going to a 9 or 10 paddle is not an option right now...I already bought them. I assumed that going down a tooth in the front would help in the sand and hill climbing. Before I changed paddles , I used to run v-paddles (sand sharks) and it would struggle up big hills. I had to stay in 3rd or 4th...using stock gearing 14-41. I bought a 13 tooth but haven't put it on yet. I weigh 180 and want the bike to hit 5th gear going up hills. How much air pressure will be good in the sand for my weight? Going down the 1 tooth will help big time. Now you see what i'm talking about with rider weight. I weigh 225 and my setup is very different than a lighter riders. I can't run the top end like a lighter rider can so I have to adjust my setup to compensate. You should be able to pull 5th and 8 paddles with a 13 up front alone. If you can't i'd be sure the jetting was correct as well. You may be rich on top. Quote Link to comment Share on other sites More sharing options...
sanddragshee Posted February 2, 2004 Report Share Posted February 2, 2004 my banshee has between 80-90 horses and i run 16-41 gearing with 21x11x8 12 paddle extremes and still blow the tires on the take-off. Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted February 2, 2004 Report Share Posted February 2, 2004 i would run a 10 paddle 21-12-8 hualer with 14-41 with low to mid 80s hp that paddle worked awsome for me if you run a 12 paddle i would run a lower gearing mabey a 13 39 Quote Link to comment Share on other sites More sharing options...
highroller Posted February 3, 2004 Author Report Share Posted February 3, 2004 sandragshee, how long of swingarm are you running? Quote Link to comment Share on other sites More sharing options...
