7mm Crank
There is a lot you have to do. One is trench the cases so the crank will fit in the first place. Second is the port timing will get screwed to hell so some port work is needed. Third you will have to compensate for the piston coming above the deck by either adding a spacer plate under the cylinder or possibly adding one on top of the cylinder or milling out the head to let the piston ride up in there. Your looking at something that is pretty expensive but if setup properly will have tons of torque and lots of HP.
