Outer Wear
gumby
i ve never used it (outter wear) and i recently purchased a 2into1 trinity kit from a fellow hq member and im wondering how much abuse can it take? is it fairly water resistant what about mud? how do u clean it? any special oil u have to put on it. you get the point. no perv posts plz although im sure ill get a kick outta of em :D
Clean it often. I know alot of guys are not gonna like this, but I always fill up my ratio rite cup with gasoline, I then dip in the outerwear and swish it around for 10 seconds. When it comes outta the gas, its clean. shake off the excess gas and take it over to your garden hose. Spray it off with water. Now all you have to do is let it dry, it will hold water in the pores. Sometimes if im in a hurry, I'll use a hair blowdryer. Hold the blowdryer up to the Outerwear and it blows\evaportes the water almost instantly. Be carefull tho, you can burn\melt the Outerwear with the hairdryer.
clean it often, but dont oil it, the oil will stick in the pores and choke off air flow. its more splash proof then it is water resistant, if mud sticks to it, the same as iol, it will block air flow, but running the single carb, you definitly want it. as far as cleaning it, ive used the meat method and ive also used the filter cleaner as well, the meat method cleans faster and is cheaper. after you clean your filter, oil it, let it soak in and slide it on, your good to go.
