Shock Coil Removal?
Dragg-on
Well, not if you have the right tools. In a pinch you can use a vise to compress the spring, and use several large zip ties to hold the spring compressed while you unscrew the eye from the shock shaft. This is very dangerous, and without enough very large zip ties the spring will snap back and either hurt you or at the very least scare the crap out of you!
If you have the option I would recommend having someone with the correct tools take it apart.
Good luck and be careful.
