Do U Have An Rc10t3?
tranny problems <_< . It grits like the gears are bad or somthing is in there but it never slips :huh: I was wondering what should i do? buy a new one or rebuild it. I have asked a couple ppl the same question they said it's a lil hard but fun.
Problem: it grits when u spin only one tire with your hand. Could it just need a new differentil(sp)? ;)
Sounds like a rebuild is in order. Never had a T3, but I had an RC10GT. I'll assume the trannies are probably very similar. Its thats the case, a rebuild will be really simple. Just a matter of replacing some bearings and maybe a gear or two depending on how bad it is. Parts will run you about $20 at the local hobby store.
Thanks, Ive tried to reach a store called hobby town usa and they say they dont carry associated stuff cuz they change the lineup to fast and when u buy in bulk that kinda sux when somthing new comes out <_<:angry::( Any i Went to the local rc track/store they said it might be the differential bearings so I might try throwing in a diferential and see what happens. If it still grit's im gonna fix da gears ect..... I'm just gonna go to towerhobbies.com and pick up a differential rebuild kit (it comes with the bearings the screw and some washers and it's only like 8 bucks ;) Yes the rc10gt and the rc10t3 are like brothers like a e-maxx and a t-maxx they are almost the same besides the chassis. And mabey stronger parts to handle the beating of nitro power. i also might throw the mip aluminum cvd's in my t3.
rebuilding the diff isn't that hard at all, a cool trick is to put silly putty in the diff to lock the rear end up, if you bash on the street at all it's more fun to bust do-nuts and 180's, my trucks are nitro though, I have never had an electric.
looks pretty simple:
Associated Differential Rebuild Kit B3/T3
Manufacturer Stock#
9351
Special Stock#
LXXH04
Tower's Low Price
$8.59
Status
In Stock
Tech Notes
NOTES FROM OUR TECH DEPARTMENT
This is the Diff Rebuild Kit for the B3 and T3.
FEATURES: Direct fit replacement parts
INCLUDES: Six thrust balls (ASCC6574)
Two diff drive rings (ASCC6367)
Two thrust washers (ASCC6573)
One diff bolt (ASCC4675)
One T-nut (ASCC4675)
One diff thrust bold cover (ASCC4675)
One Diff spring (ASCC4682)
REQUIRES: A 5/64" allen wrench for assembly
Installing onto the vehicle
SPECS: See individual stock numbers for specs
tjt 0602602
ir/kh
This is from towerhobbies.com
I would take it apart, see if there is grit in the diff or bearings, take it apart check everything over, then make your order...Might save you some cash...
I don't have an RC10 but I have an HPI savage...About to toss the tiny 21 BB back in it for this weekend, because I had to send the S25 .25 back to HPI.... Grrrrrrr
Best thing is RCs are easy as hell to work on...
ahhhhhh rc cars back before i could drive only 3 years ago i was heavly in rc i had everything from a losi xxlr to kyosho 1/10 scale carselectric to gas and from slow to fuckin fast then i realized instead of spending 5k on rc i can get a car... chose the real driving instead
