Gear On Olds
For all you guys who go to glamis what gear ratio are you running on olds hill? I am running a stock 13:41 ratio And i am wondering what is the best ratio for going up the hill? for all you who don't go to galmis olds hill is huge sand hill.
I thought stock was 14:41? :unsure:  I'm running the same gearing you are.  Depending on your mods, you could probably go to a ?stock14? or a 15 tooth front & be able to pull it a bit faster up the long hill.  Just MHO... ;)
Actually there were 2 or 3 years that came with a 13 tooth front and 22" tires. I think it was 87-89.
I believe stock is 14 tooth, so take a look.
My favorite ratio with FMF pipes and a K&N was 13:41
I could easily pull 4th and almost 5th up the steep side.
14:41 was a little better on the less steep side, since you don't need to drop a tooth to get into 4th on that side of the hill...
I like the steep side better for racing though, especialy against 4 strokes ;)
