What Do You Use To Adjust Your Sag?
erbilabuc
Im thinking to just using a screwdriver and a hammer but I know they make a tool somewhere. Any help? oh this is for the rear shock
thanks
try taking the weight off the spring and then spinning the spring with your hand the way you want it to go...IE: tighten or loosen. Have to loosen the lock ring first though.
I adjust my sag by taking a good look at the girl that runs the gas station by my work :o
If you're talking about a stock rear shock, use a spanner wrench. Either buy an adjustable/universal type, or measure the distance (diameter) between the outside ears, and the distance (diameter) between the grooves and get ye to an Ace Hardware or an auto parts store with yer measurements. Have someone help you if you cant find it.
Spanner Wrench.
Get one. ;)
