Guest dazed&confused Posted January 15, 2004 Report Share Posted January 15, 2004 took the shee in to the shop,,, they cleaned everything from top to bottom side to side...brought it home rode awsome for 2 days, end of second day it died like a plug foweld, replaced both plugs... my shee wont kick over at all now...any suggestions out there...need some help quick ...gotta ride...lol..thanks in advance Quote Link to comment Share on other sites More sharing options...
spoin39 Posted January 15, 2004 Report Share Posted January 15, 2004 What do youmean, won't start, can't even move kickstarter? Quote Link to comment Share on other sites More sharing options...
shortys racing Posted January 15, 2004 Report Share Posted January 15, 2004 took the shee in to the shop,,, they cleaned everything from top to bottom side to side...brought it home rode awsome for 2 days, end of second day it died like a plug foweld, replaced both plugs... my shee wont kick over at all now...any suggestions out there...need some help quick ...gotta ride...lol..thanks in advance if it won't kick over then you have got some issues... have to take it apart. If it just won't start then check the CDI box, I had a few do that this year. Look for the seal around the wiring to be broken or a hole leading water into the box. Quote Link to comment Share on other sites More sharing options...
Guest dazed&confused Posted January 16, 2004 Report Share Posted January 16, 2004 it kicks...just dont have any fire...i checked the plugs they are getting spark,getten good fuel flow to the carbs,ok need to know were the cdi box is, i checked the wires (all of them) no shorts or exposed wires. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted January 16, 2004 Report Share Posted January 16, 2004 Check the kill switch??? J/k.....test the stator. mine did the same thing on my '95, was running like a champ and then just died like I hit the kill switch...Call Ricky Stator and he'll tell you the ohms and color wires to test. I can't remember off the top of my head. It'll take you 5 minutes to test the stator.....BTW, the stator has two areas in it, one for the headlights, and one for ignition, so even if the headlights come on while kick, it doesn't matter... Quote Link to comment Share on other sites More sharing options...
superchicken Posted January 16, 2004 Report Share Posted January 16, 2004 the cdi box is under the seat Quote Link to comment Share on other sites More sharing options...
boonman Posted January 16, 2004 Report Share Posted January 16, 2004 Check the orange and black wires on the primary side of the coil. Now, go out and get a service manual. Either Clymer or Yamaha. Inside it will tell you step by step how to test the stator..... Quote Link to comment Share on other sites More sharing options...
SDD Posted January 16, 2004 Report Share Posted January 16, 2004 Try adding some more gas to your gas tank. Even if it seems as if you have enough adding a little more gas to the tank will not hurt anything. Quote Link to comment Share on other sites More sharing options...
National Banshee Posted January 17, 2004 Report Share Posted January 17, 2004 If you are getting good steady spark, and fuel, you might want to check your compression. Good luck! Quote Link to comment Share on other sites More sharing options...
