Rz350 Cylinders
ruff_rida69
hes says that the bore size of the cylinders are 75.00mm, which i e-mailed him about it just to make sure he didn't make a typing mistake, but he hasn't repleyed yet, I think he ment to type 65.00mm instead of 75.00mm. Thanks, Jonathan
I would find out befor eyou buy....65mm and 75mm is alot of difference. You can fit a 75mm but the transfers would be small as hell.......
well he changed the auction info after he e-mailed me this about the cylinders,
The cylinders are currently .75mm over (.060") making the bore size 64.75mm.
and this is what he said when i asked him if the rz stator and flywheel came with the kit,
The Banshee stator and flywheel are identical to those of the RZ
He's not too smart if you ask me, but I'll probey buy it any way because I've been wanting to do an rz conversion for a long time, Thanks for all the help, Jonathan
