johngolfvr6 Posted January 13, 2004 Report Share Posted January 13, 2004 hey guys I need to know what jets to put in my banshee. It has been board out .080 over with stock pipes and boyesen reads, The jets I think are stock, it was board out .040 when i took it apart to rebuild it. It runs good, Just wondering if I can get more power out of it by jetting it, thanks Quote Link to comment Share on other sites More sharing options...
shortys racing Posted January 13, 2004 Report Share Posted January 13, 2004 if it's still all stock and just bored out .080 then it prob. is close to good now. they come pretty rich from yamaha. At least at sea level anyways..... do a plug check and see how close it is and go from there. Quote Link to comment Share on other sites More sharing options...
johngolfvr6 Posted January 26, 2004 Author Report Share Posted January 26, 2004 thanks for the info, I forgot to say i also have a k&n filter if that matters Quote Link to comment Share on other sites More sharing options...
HILKILR Posted February 4, 2004 Report Share Posted February 4, 2004 if it is bored, running the k&n, and if you are running aftermarket pipes, then the 280 is close to the best . you must look at everything you have done to the bike. example my is; fmf gnarly, boost, reed spacers, pro-comp filter, cut box and the 280's are on the money. good luck Quote Link to comment Share on other sites More sharing options...
sredish Posted February 4, 2004 Report Share Posted February 4, 2004 have you checked the spark plug under wide-open-throttle? That is really the only way to tell. No one can really tell you what you can run, you have to see how your shee is running. Take it out where you can get some speed and run it in 5th or 6th with the throttle wide freaking open, and kill the motor. Then check your plugs and it will tell you if your rich or lean. Also, if you want more power, get some pipes. Quote Link to comment Share on other sites More sharing options...
