Yaxy Posted January 12, 2004 Report Share Posted January 12, 2004 Well my 89 is due for a new clutch basket and from what I have seen I only get the basket not the gear that the basket is attached to. I assume that first I need to drill out the rivets that hold the basket to the gear but how do I attach the new basket to the gear? I can also assume that the assembly would have to be balanced and symetrical to reduce vibration. Any suggestions? Chris Quote Link to comment Share on other sites More sharing options...
fixitrod Posted January 13, 2004 Report Share Posted January 13, 2004 The new basket should come with screws. You will need some red loctite. As far as balance, the are balanced enough for the job they are doing. Not much you can do about it. Quote Link to comment Share on other sites More sharing options...
Yaxy Posted January 13, 2004 Author Report Share Posted January 13, 2004 What size drill bit should I use and should I drill from the basket side or the gear side? Chris Quote Link to comment Share on other sites More sharing options...
