Carb Bowl Hits The Clutch
runts
Hey everyone I am new to banshee but know alittle common since about
anything and what is wrong is the banshee has 34mm keihin carbs on it and
the bowl hits the little clutch plate I dont know what its called but its right under
neath the carb bowls and what it does is when you let the clutch out it hangs on
the bowls. The bowls are setting to LOW. Please help
im not really sure how you would go about fixing that. maybe by havin smaller carbs on it because stock banshee carbs dont hit. would have a hydraulic clutch help? i say this just because i had one and i liked it alot better than the stock set up. i dont know if it would solve the problem or not. im guessin the only way to fix it is with smaller carbs.
reed spacers will solve the problem - BUT with spacers, you lose a few HP, but gain a little torque - from the words of Dynoedge racing. I've seen alot of the ground down bowl bolts - and that works too - my 34mm carbs are just normal, and i just let the clutch arm hit it - it moves it maybe a mm or so - but i live with it
