Cleaning Ur Plugs
CrRider80
sometimes i get a oiled fouled plugs i went through like five. then one day i decided to wash them so i took a bar of soap n a old tooth brush. i scrubbed the bar of soap to get the tooth bruss soapy then i got to work on the plug after i let the plugs rinse off in hot water then i boiled water n let the plugs sit in the water. i went to test them n they work like new
:rolleyes: Or you could just jet your engine correctly. Have never fouled a plug. Even when running it a little rich and riding in a higher gear to save fuel in trails. Just open it up once in a while to clean it up. I change them out every so often before going on big rides and such, and always carry spares......you never know when your buddy on his 250R might need one.
Same here .
Proper jetting is a much easier and cheaper way of prolonging your plugs. I always have 2 spares on the bike and try to keep 4 more in camp in case I have a really bad trip. I've never had a plug foul so bad that it HAD to be replaced since I got the shee. Just change it out every couple of trips to keep em fresh.
alright now this i gotta comment on! spray them bitches with either (starting fluid) and light em up with a lighter. . . .they clean up nice that way. or use gas. i also use some sand paper to clean em out. best is just to buy new ones but if ur low on funds sometimes u gotta clean em, i kno i've ben there
I agree with Sandman completly, I was letting my brother in law ride the Shee and he was just learning to ride and he fouled out my plugs. I didn't have any spares since I don't foul plugs often, so I pulled the plugs and put a lighter to them for a while and bingo! I was able to get it home and change them. Might not be the best , but if your stuck somewhere and need to get it back to the homestead it will do.. B)
