28mm Carbs With 30mm Taperbore
To use the added carb you should put on a aftermarket head with like 20cc domes. Port your reed cages and get some TDR reeds, or get v-force II reed cages. Advance your timing about four degrees and run some higher octane gas. Get some K&N pod air cleaners or toomy upright one into two air cleaner. Now your motor can kinda handle the added gas. That LRD web site puts the carb mod at about last as far as where to go to add hp to the banshee.
I'd have to say stock carbs for my setup, but I"m running midrange pipes.....I'm sure the high revs w/ porting will benefit more from larger carbs, but how much is the question....BTW, I lost hp across the whole curve w/ ported stock carbs also....
