Kidd Posted January 10, 2004 Report Posted January 10, 2004 I have a 98 Banshee. Totally stock. I removed the snorkel and rejetted to 220 mains. seemed to run good but cold weather starting takes forever. Pulled plugs and they were black and wet. put fresh plugs in and still takes 10 kicks and a lot of patience and a few more tries to get it to stay running. last summer the plugs were so clean it looked like they were from a new car. Also looking for a set of pipes. Maybe pt`s or dmc`s Preferrably spark arrestors. Any ideas? Quote
blk02banshee Posted January 10, 2004 Report Posted January 10, 2004 Usually, when it gets colder out, you need to richen the airscrews. This would help it start easier, but you said your plugs are wet, so I'm confused.lol What is your elevation where you are? and how cold is it? Quote
BansheeBoy17 Posted January 10, 2004 Report Posted January 10, 2004 I would do what blk02 said ... try the air screws - here is a link if you dont know how to adjust them CLICK HERE MAN !!! Quote
Kidd Posted January 10, 2004 Author Report Posted January 10, 2004 Thanks. I live in Idaho, 2600 elevation, 30 degrees or so. I turnd the screws in 1/4 turn. Sounded better, but havent tried starting it cold. I got a pro flo and uni for it and wondered if it needs to be richened more. Plugs could have been wet from the thirty or forty kicks to get it running. This aint a 4 stroke. Quote
psd1 Posted January 10, 2004 Report Posted January 10, 2004 Check your compression...it may be time for a rebuild. Usely it is necessary to go higher (bigger) on the main jet when it gets colder since the air is more dense. Quote
