lectro99 Posted January 8, 2004 Report Share Posted January 8, 2004 My chain is lose? how tight should it be and how do i tighten it? Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted January 8, 2004 Report Share Posted January 8, 2004 Do yourself a big favor, get yourself a clymers manual. With a stock shee you'll have to loosen the bolts securing the bearing carrier, adjust the little adjuster bolts on the back of the carrier, tighten them up EQUALLY on each side and this will pull the carrier back; thus tightening the chain. Give youself about a 1 1/2 inches of play & you should be alright. But like I said,...get yourself a clymer manual and it will walk you through step by step. One of the best $30 I ever spent. You may even find you an online manual,...I think I remember seeing one linked off a post one time--you may search for it. Hope this helps. Quote Link to comment Share on other sites More sharing options...
