Tires/swingarm Length?
What size of tires ( & # of paddles) should I run with an 8" arm? I ride only in the dunes and my bike is pretty modified. 4mm stroker crank, bored 20 over, 35 pwk's with pod filters, cool head with 20 cc domes (175 psi), t-5's (going to CPI's), ported, +4 timing. I was thinking 12 paddles on 22x11x8 tires. What do you guys think?
You need to figure out what paddle based on horsepower output more than swing arm length. Also consider what you will be doing with them, flat drags are completely different than hill shooting. I wouldn't be able to tell you what works in a flat drag situation, but my 410LR motor works bet with 22x12x8 10 paddle ultralites. I also run a +8 swing and am on the bottle. This is a typical hill shooter setup. If I were to run 12 paddles I would be TOO hooked up. Without the bottle i'd prolly run the 9 paddle.
Hope this helps but if you can post some better numbers and purpose i'm sure someone can give better advice.
