Next Best Thing
The cheapest and most needed mod is the water pump impellar, It will keep it running cooler and that is more consistent HP. The head is another good one but what about suspension? If it's stock you will notice a big difference in a set of good shocks, or a new axle that is wider or A-arms.
Port it and be done with it!You will see the most noticable difference.If you get a cool head or something done to your head you will have to change the dome in the aftermarket head or get your head rechambered again to your port work.So just port it and do the head the same time and be done with it!
