Checkmate Posted January 5, 2004 Report Share Posted January 5, 2004 I am running an amp link and decieded to go to a 15 tooth front sproket. When i went to put my chain back on, i am short when trying to connect the master link. I have the axle loose and all the way forward. So my question is.....does anyone run a 15t front sprocket and an amp link? what did you do for a chain? What size chain do i need....they only come even #'s right....so a 106 link??? thanks. also....what is the best way to remove links if i decide to get a 110 link and start hacking away. Quote Link to comment Share on other sites More sharing options...
boonman Posted January 5, 2004 Report Share Posted January 5, 2004 Get a longer chain, or go get ya a piece and add it on..... When I cut a chain, I grind the head of the pin down, and then tap it out with a punch..... I do alot of chain work at my day job, and that's the way we do it. There are chain breakers, but they are POS' in My opinion... Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted January 6, 2004 Report Share Posted January 6, 2004 I agree chain breaker SUCK Grind then punch Sounds Nasty but it's the best way. Quote Link to comment Share on other sites More sharing options...
Proquad101 Posted January 6, 2004 Report Share Posted January 6, 2004 If you cant get the chain the right length get a drimell or rotory file and make the holes a little longer where your axle carrier bolt sets in the swingarm ( the bottom holes). I have done it to many bikes it works good. do a little at a time and check the length. Quote Link to comment Share on other sites More sharing options...
