wheeleymaster99 Posted January 5, 2004 Report Share Posted January 5, 2004 i was wondering what would be a good head and what size domes whould be best and what will i need to change after putting on the head my mods are listed below and if anyone has a good set of head and domes for cheap let me know Quote Link to comment Share on other sites More sharing options...
Just for fun Posted January 5, 2004 Report Share Posted January 5, 2004 Noss head where you dont have to change out the studs with 20cc domes. Quote Link to comment Share on other sites More sharing options...
dlnoss Posted January 5, 2004 Report Share Posted January 5, 2004 The best dome also depends on how your stroker is set up and the porting. Is your head 'stock' now or modified? Quote Link to comment Share on other sites More sharing options...
wheeleymaster99 Posted January 5, 2004 Author Report Share Posted January 5, 2004 now its stock Quote Link to comment Share on other sites More sharing options...
dlnoss Posted January 6, 2004 Report Share Posted January 6, 2004 I guess you are running a base spacer plate. You are welcome to call if you want. There are lots of things to consider like what compression you want, what it is now, if your cylinders were ported when you did the stroker, what your deck height is, etc.. -David Quote Link to comment Share on other sites More sharing options...
wheeleymaster99 Posted January 6, 2004 Author Report Share Posted January 6, 2004 well the guy befor me put the stroker in so i dont really know if might be able to find out if i really need Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted January 6, 2004 Report Share Posted January 6, 2004 well the guy befor me put the stroker in so i dont really know if might be able to find out if i really need you should find out who did the work, so you can call the guy who built the engine and ask him what kind of head you need. How do you know the stock head has not been milled and squish adjusted? Quote Link to comment Share on other sites More sharing options...
dlnoss Posted January 6, 2004 Report Share Posted January 6, 2004 If you don't mind the down time, you can send the head to me and I'll check it to see if it's been modified. It would give you a starting place. If you were going to do this, it would be good to check the compression before removing the head. Quote Link to comment Share on other sites More sharing options...
wheeleymaster99 Posted January 7, 2004 Author Report Share Posted January 7, 2004 alright i'll talk to the guy i got if from he owns a jasper egine and trany shop so i'll bet he knows a lot of ppl who can do that stuff but i'll find out who did the work on it Quote Link to comment Share on other sites More sharing options...
