Tharris24 Posted October 8 Report Share Posted October 8 So I just got a freshly built 421 banshee. It starts up and high idles but once you put it in gear the idle goes back down to normal. Then when you go to get on it, it sounds like it’s sputtering and when you get all the way to 6th, it sounds like it’s turning off and on. New spark plugs. I synchronized the carbs today and i got the idle issue fixed but it’s still running horrible. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted October 8 Report Share Posted October 8 Unplug tors brainSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
HeavyHauler Posted October 8 Report Share Posted October 8 Quote Link to comment Share on other sites More sharing options...
Tharris24 Posted October 9 Author Report Share Posted October 9 It idles fine and it will respond to throttle in nuetral and it’s crispy. But when you put in gear it doesn’t have the power that it should. I tried posting a video. But the video is too large Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted October 10 Report Share Posted October 10 Who assembled the engine? Did it get leakdown tested? High idle can be cause by an air leak….. and considering it’s a new motor….. it may be lowering the idle when in gear because of slight mis-adjustment on the clutch side of things Quote Link to comment Share on other sites More sharing options...
Tharris24 Posted October 10 Author Report Share Posted October 10 You may be on to something with the mis-adjustment. Because when it’s running you can’t put it back into neutral. Bring home an ohm meter from work so I can rule out the stator. Quote Link to comment Share on other sites More sharing options...
Tharris24 Posted October 10 Author Report Share Posted October 10 17 minutes ago, Jereme6655 said: Who assembled the engine? Did it get leakdown tested? High idle can be cause by an air leak….. and considering it’s a new motor….. it may be lowering the idle when in gear because of slight mis-adjustment on the clutch side of things Also, it passed the leak down test Quote Link to comment Share on other sites More sharing options...
Tharris24 Posted 45 minutes ago Author Report Share Posted 45 minutes ago Update:-Carbs are synced-New dynatek coil-Noticed that the bowls were on the wrong carb. Swapped them-Installed choke equalization tube Starts up first or second kick. Idles fine. But still bogs under a load. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
