hi guy quick question on my banshee jugs .
i have a 1 piece jug serval kit my ring broke today .
looking down into the jug cylinder  with the piston in as it  is in the banshee i see the big exhaust port  i see two very small port s to the side of the exhaust port wich have a divider well the divider piece chipped off a tad  nothing bad but enough to notice
will this really hurt anything after i clean it up ?
shoukd i just dermal the other cylinder out to match. or not even worry about it ?
i am not sure why those two dime die ports do
Bring it to shop. It might be enough to snag a ring. Also, you might need plating repair.
This is something that can easily be fixed but by a professional
here is. a pic the upper port goes to the intake  the lower one goes down to the crankcase as you can see the littil middil divider broke off.      so can i hone it out do. littil cleaning  and be good to go ??
i dont know how important the divider is
Thats going to require a professional to look at it and probably plating. Im no expert though, if it were mine id reach out to Millenium plating and ask them
