What mods next
I have a 2001 banshee that I restored last year, the only modification to the engine is that it has a bore which was there when I bought it, don’t know how good it is. Other than that, I have t5s, pod filters, some taiwanese 28mm pwk carbs from a company called maikuni (not mikuni). What would be the cheapest hp gain mods to do next? I was thinking a cool head.
The Chinese carbs always cause problems .
beat bang for the buck is a port job to match your pipes, new reeds v force or pyramid. No need for a cool head, shave your stock head. You’ll notice big gains.
if you have more money get a striker crank for an extra 7-10 hp
  • Thanks 1
You know what types of shops I need to look for to shave the head? What do I need to tell them to do.
also, I feel some smoke coming out of where the cylinder joins the pipe, I think it’s because there’s no spring hook so one of the springs r missing. Does this effect performance?
16 hours ago, Jereme6655 said:
You can get your head shaved through any of the reputable site sponsors on here…. They can take care of that while they do your port work
Would my bike run fine with +4 timing and a stock engine? I want to find someone good at shaving the head near me, I think it would take some time. So I want to get the timing plate on before that.
Your bike will run +4 timing fine without any more modifications. There are different amounts that can be shaved off the stock head….. that’s why I say to send it with your cylinders to a site sponsor. These guys have been doing it forever and will be able to shave the head to what your motor is ported for.  Take too much off because you had a regular machine shop do it, and you could be asking for a nightmare of problems….. like detonation, improper squish, etc…..
