pc_55 Posted August 23 Report Share Posted August 23 I’m out in Minnesota Looking for a super super good mechanic, reputable. I have a 1996 banshee, I had a shop do top end, bottom end, clutch, new chain, new heads and new cylinders. They can’t get bike started. I need to travel with bike or fly someone in, I would need you to know you stuff and know it well, with proof. Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted August 23 Report Share Posted August 23 10 hours ago, pc_55 said: I’m out in Minnesota Looking for a super super good mechanic, reputable. I have a 1996 banshee, I had a shop do top end, bottom end, clutch, new chain, new heads and new cylinders. They can’t get bike started. I need to travel with bike or fly someone in, I would need you to know you stuff and know it well, with proof. I'm in MN too, who did the work? Where in MN are you? I might be able to come look! These things are simple as shit. You do NOT need to fly someone in, or travel if you can't follow simple directions. What happens when you try and kick it over? Check to make sure it's getting fuel? Quote Link to comment Share on other sites More sharing options...
pc_55 Posted August 23 Author Report Share Posted August 23 Cannon power in cannon falls did the work, I was told it needed carbs adjusted, too much gas is getting into the spark plugs, put new spark plugs in and it won’t start, it try’s to kick over but won’t, then floods. Sorry im new to the banshee/4 wheeling world. Would pay you to come out or will drive in if you’re really knowledgeable I also have OEM carbs on the way just in case. I’m 15 away from cannon falls Minnesota. Thanks for your response. Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted August 23 Report Share Posted August 23 52 minutes ago, pc_55 said: Cannon power in cannon falls did the work, I was told it needed carbs adjusted, too much gas is getting into the spark plugs, put new spark plugs in and it won’t start, it try’s to kick over but won’t, then floods. Sorry im new to the banshee/4 wheeling world. Would pay you to come out or will drive in if you’re really knowledgeable I also have OEM carbs on the way just in case. I’m 15 away from cannon falls Minnesota. Thanks for your response. I'm in west metro Minneapolis, not too far from you. What carbs are currently on it. Sounds like the floats aren't adjusted right. takes 10 minutes to do I would NOT go back to Cannon Powersports. If they can't figure this out, they're clueless. I could probably come out next week before Thursday. I'll send you a private message Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 23 Report Share Posted August 23 Turn fuel off & keep trying...see how it reacts & report back 1 Quote Link to comment Share on other sites More sharing options...
registered user Posted August 24 Report Share Posted August 24 skeeter racing out in orygon do top notch werk. hit him up bruh 1 Quote Link to comment Share on other sites More sharing options...
pc_55 Posted September 10 Author Report Share Posted September 10 On 8/23/2024 at 2:57 PM, 375hp banshees said: Turn fuel off & keep trying...see how it reacts & report back Same thing, I have Brand new OEM CARBS, looking to install. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted September 11 Report Share Posted September 11 Were plugs still wet? Quote Link to comment Share on other sites More sharing options...
pc_55 Posted September 11 Author Report Share Posted September 11 No Quote Link to comment Share on other sites More sharing options...
gusto Posted September 11 Report Share Posted September 11 On 8/22/2024 at 9:22 PM, pc_55 said: I’m out in Minnesota Looking for a super super good mechanic, reputable. I have a 1996 banshee, I had a shop do top end, bottom end, clutch, new chain, new heads and new cylinders. They can’t get bike started. I need to travel with bike or fly someone in, I would need you to know you stuff and know it well, with proof. The shop cant get the bike started after this? Are they fixing it for you? Do you have spark? 1 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted September 12 Report Share Posted September 12 Make sure the orange and black wires attached to the spade terminals on the coil are on properly and the wire is still connected to the spade inside the insulating boot. Seen them get bumped and broken while working in the vicinity. 1 Quote Link to comment Share on other sites More sharing options...
pc_55 Posted September 13 Author Report Share Posted September 13 Will try. Feeling like giving up. Quote Link to comment Share on other sites More sharing options...
pc_55 Posted September 15 Author Report Share Posted September 15 Bike running. Tors delete is what was needed. Quote Link to comment Share on other sites More sharing options...
registered user Posted September 16 Report Share Posted September 16 try a vitos boost bottle. tors delete aint no good Quote Link to comment Share on other sites More sharing options...
HeavyHauler Posted September 16 Report Share Posted September 16 I just did a Motion Pro TORS delete kit with the idle screws on my banshee this past weekend. Just a little added information depending on the year of your banshee but on my 05 I had to unplug the TORS control unit that is located by the front fuel tank bolt on the left side (clutch lever side) to make my banshee run after doing the delete kit. I totally removed the control unit. Quote Link to comment Share on other sites More sharing options...
