Banshee leaking oil
Investigate it better. Did you smell it? It could be the premix leaking from your carburetors that is running down through the center drain hole that’s in the cases. If it’s trans oil then you will have to split the cases and reseal it.
  • 3 weeks later...
After riding all weekend, I put my ninety eight Banshee in the lower back of my truck and took it home. When I arrived, I observed a small pool of Oil on the mattress of my pickup and started to look for the leak. There are 8, 12mm, bolts/nuts on the bottom of the Banshee transmission, positioned simply forward of the Tranmission Oil Drainplug. These eight bolts are coated up in two rows of four. One of the bolts closest to the Drainplug became wet and regarded to be leaking.
