dittmer Posted January 3, 2004 Report Posted January 3, 2004 i bought a K&n power kit on ebay and it came with stage 3 jetting. i think this mite be to much for my almost stock shee.the jetting kit came w/270 and 280 mains and new needles. i am at about 750' with the snorkel removed and 200 mains where should i start with mains and should i use the needles that came w the kit or the stockers? Thanks also i did try the 270 mains and new needles, it ran like a turd Quote
dittmer Posted January 4, 2004 Author Report Posted January 4, 2004 stock pipes the only upgrade i have is a cool head and i dont think it makes a dif Quote
00BANSHEE Posted January 4, 2004 Report Posted January 4, 2004 If all you are going to do is install the K&N filter and keep everything else the same you could keep the stock needles and bump your mains up to 230-240 and to a plug check from there. Save those larger mains and aftermarket needles until you get some pipes other than stock. Quote
dittmer Posted January 4, 2004 Author Report Posted January 4, 2004 sounds like a good idea i have 220 and 240's ill give them a try thanks Quote
