quadsrlife Posted January 3, 2004 Report Share Posted January 3, 2004 ok ive got a question about these aftermarket cylinders ive been reading about. like whats the difference between a cheetah/t-rex and a stock cylinders. for example if there were two banshees with exactly the same mods except one had a cheetah 500 and had stock cylinders resleeved with big bore sleeves and bored to 500 why would the cheetah so much better and what would make it so much better than the other one,(remember other than that they have the same exact mods). any help or awnsers would be appreciated. thanks Quote Link to comment Share on other sites More sharing options...
NYUK Posted January 3, 2004 Report Share Posted January 3, 2004 cheetas are nikasil bore, trex are sleeves. a 500 cc cheetah and a big bore stock cylinder bike, the difference isthe cheetas have a much bigger transfer area, using the air and fuel more efficiently.sleeves and nikasil are your choice.what is closer to you .someone who can bore a sleeve, or a nikasil shop that can re nikasil your cheetas.nikasil is hard almost diamond like. i had a piston shatter last summer. not even a scratch on the bore. Quote Link to comment Share on other sites More sharing options...
quadsrlife Posted January 3, 2004 Author Report Share Posted January 3, 2004 thanks ..well is there a big difference in power between having the stocks resleeved and the cheetah/trex Quote Link to comment Share on other sites More sharing options...
NYUK Posted January 3, 2004 Report Share Posted January 3, 2004 the aftermarkets may be more efficient and reliable.i would say the aftermarkets would have more power or potential for the hp and torque than the big bore stockers. Quote Link to comment Share on other sites More sharing options...
Chemical Castration Posted January 3, 2004 Report Share Posted January 3, 2004 I agree with NYUK the transfer area on the stock cylinders are too small, there's only so much you can do to the stock cylinders. The aftermarket cylinders have a better design and are made to go beyond what your stock cylinders can do. They also have powervalves in them witch help a ton with the lightswitch powerband that banshees are famous for. If you have aftermarket cylinders with a stroker crank your banshee can cruise around like a thumper! Quote Link to comment Share on other sites More sharing options...
quadsrlife Posted January 3, 2004 Author Report Share Posted January 3, 2004 thanks for helping clear that up ...do u happen to know if anyone has a set of those aftermarket cylinders for sale like a used set. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted January 3, 2004 Report Share Posted January 3, 2004 check planetsand there is usuall someone selling something there. Quote Link to comment Share on other sites More sharing options...
NYUK Posted January 3, 2004 Report Share Posted January 3, 2004 i just seen a set of t rex`s on there.thats where i got my cheetas. Quote Link to comment Share on other sites More sharing options...
