realdesertkickin Posted May 20 Report Share Posted May 20 New and learning here... Is this hole legit?.. it doesn't line up with the drain hole under the carbs... It's not leaking and the bike runs fine... Quote Link to comment Share on other sites More sharing options...
realdesertkickin Posted May 20 Author Report Share Posted May 20 3 minutes ago, realdesertkickin said: New and learning here... Is this hole legit?.. it doesn't line up with the drain hole under the carbs... It's not leaking and the bike runs fine... sorry pic didnt post....figuring out delete now Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted May 20 Report Share Posted May 20 If it's the hole on the cases, yes, it's legit Quote Link to comment Share on other sites More sharing options...
realdesertkickin Posted May 20 Author Report Share Posted May 20 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted May 20 Report Share Posted May 20 Drain hole from top of case. Nothing to worry about. Quote Link to comment Share on other sites More sharing options...
realdesertkickin Posted May 20 Author Report Share Posted May 20 OK thanks!! appreciate it...... Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted May 20 Report Share Posted May 20 1 hour ago, realdesertkickin said: OK thanks!! appreciate it...... You're welcome. Quote Link to comment Share on other sites More sharing options...
SKEETER Posted May 20 Report Share Posted May 20 Had much higher Hope's for what this was gonna be 1 Quote Link to comment Share on other sites More sharing options...
