01bansheefox Posted January 3, 2004 Report Share Posted January 3, 2004 I dont know jack really about performance parts but what would be better for my money and also performance. I thought I have heard some suped stock parts are better than aftermarket, could be wrong. Shaved stock head or aftermarket one? Dont know what its called but doing something to your stock carbs, or just get bigger ones. Quote Link to comment Share on other sites More sharing options...
ruff_rida69 Posted January 3, 2004 Report Share Posted January 3, 2004 well shaving your head is cheaper,but you could look into noss head which have better cooling and you can change the domes to any size, anytime you want, as long as you get the right octane to support the higher compression, and i think you mean boring your carbs, i think you can bore them out to a max of 28mm "not sure" or you can spend more money "probley bout $250 more" depending on the size of new carbs you want, but shaving your stock head, and getting your carbs bored would be the way to go if your low on cash. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted January 3, 2004 Report Share Posted January 3, 2004 I agree on both. Used pipes in great shape are good value too. Quote Link to comment Share on other sites More sharing options...
01bansheefox Posted January 4, 2004 Author Report Share Posted January 4, 2004 I run K&N with SST's and 280main jets. Quote Link to comment Share on other sites More sharing options...
Checkmate Posted January 4, 2004 Report Share Posted January 4, 2004 never heard of boring the carbs? i guess you would bore out the slide holes??? then get bigger slides?? how do you benefit from this? Quote Link to comment Share on other sites More sharing options...
Big Blue Posted January 4, 2004 Report Share Posted January 4, 2004 no when you bore the carbs you are opening the diameter from front to back. Quote Link to comment Share on other sites More sharing options...
evil Posted January 4, 2004 Report Share Posted January 4, 2004 never heard of boring the carbs? i guess you would bore out the slide holes??? then get bigger slides?? how do you benefit from this? like big blue said and it flows more. thats where you get the extra go from. later Quote Link to comment Share on other sites More sharing options...
