bigred250 Posted May 11 Report Share Posted May 11 I bought an 89 J-arm Banshee and it is missing the entire front brake system. Will the A-arm 91-06 Brake calipers work? Picture of hub and spindle below. Thanks https://ibb.co/93d89G4 Quote Link to comment Share on other sites More sharing options...
JerzOutlaw350 Posted May 11 Report Share Posted May 11 (edited) Check with either one of them. They may have what you are looking for. https://westcoastatvparts.com/ https://redo-parts.com/ Edited May 11 by JerzOutlaw350 1 Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 11 Report Share Posted May 11 Im just here to say hi to jerrod. Just to find out its only 250 ...not bigred350X I think 89 stuff was only the same a few years tho &OG's right ...wc or redo are good choices Quote Link to comment Share on other sites More sharing options...
bigred250 Posted May 12 Author Report Share Posted May 12 Can anyone verify if I have the 87-89 spindles? I would hate to buy the 87-89 brake calipers just to find out later that the spindle has been changed to the 90-06 style. Quote Link to comment Share on other sites More sharing options...
JerzOutlaw350 Posted May 12 Report Share Posted May 12 The picture of the J-arm spindle / knuckle that you posted “ IS “ for the model year 87-89 which requires part # 1UY-23501-01-00 Left Side & 1UY-23502-01-00 Right Side. Then for the A-arm spindle / knuckle for the model year 90-06 which requires part # 3GD-23501-10-00 Left Side & 3GD-23502-10-00 Right Side. Here is a picture of what the spindle / knuckle looks like for the 90-06 Banshee. The picture that I posted is from a 1997 Banshee that Im currently working on for a friend. If you look the picture that you posted and compare it to the picture that I posted you can definitely see the difference between the spindles. I also circled the caliper bracket bolts in my picture to show how the spacing is different from the 87-89 Banshee in your photo and the 90-06 Banshee that is in the photo that I posted. Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 12 Report Share Posted May 12 The extended ears for the caliper mount on the spindle and the lack of countersink on the hub for the rotor bolts tells me you for sure have the early stuff. 1 Quote Link to comment Share on other sites More sharing options...
