Compression, Help
bizanchee
help! i always thought compression is higher on warm cylinders....i mean thats how we test the compression on aircraft. ok heres the deal i am running 21cc domes at sea level on a motor that has never been rebuilt i checked cold first and then hot and here is what i found:
Cold left- 145 Right-150
Hot Left-137 Right- 135
?? stumped but ok
i never checked the compression prior to installing the 21cc domes. i Know that the 21cc domes should (on a fresh motor) give 157 psi at sea level. basically i dont know where i stand.....do i need to do a top end?? if not then when? what are the compression limits? thanks for all your help guys
$54.95 from harbor freight. you need a compressed air supply
to use it. screws into the spark plug port and guage measures
air leaking past rings and or reeds. could probably be adapted
to pressure test crankcase as well i would think. i dont know
off hand why your compression is lower when hot...but i think
the cold numbers are a better guage for determining top end
condition. the leak down test cant be beat though :) .
Also just a thought. leak down on a two stroke ???  its only going to come out though the crank seals and if it bleeds by the rings??? Out the crank seals so I do not know where people are going with that???? rings or seals and if it needs one it probably needs the other
huh? :blink:
i do them at work all the time moron...not on banshee motors...mostly
on four strokes...but also on 2 strokes. i am a factory authorized
service tech for lincoln electric...and engine driven welders are 4cycles
(burco makes a cool 2stroke powered welder though) but my shop
also does warranty service for stihl and homelite. i have done leak
down tests, as ive said, and found problems in the past w/rings and
reeds. i have different provisions for pressure testing the crankcase
but same theory applies. a 2 stroke is a 2 stroke and your obviously
an uneducated, babbling fool :angry:
