Dragg-on Posted January 2, 2004 Report Share Posted January 2, 2004 Im wonderin if its possible to change timing without removing the flywheel. Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted January 2, 2004 Report Share Posted January 2, 2004 i got one no you can't change the timing without removing the fly wheel but usaly you don't go around changing your timing to often Quote Link to comment Share on other sites More sharing options...
mcaf29 Posted January 2, 2004 Report Share Posted January 2, 2004 I have a ricky stator timing plate and I can change my timing without removing my flywheel. I use a closed ended wrench (10mm I think) that has a bit of an outward taper (most do) to loosen the bolts. Just loosen all three and turn it or I very lightly tap it with a rubber mallet if it refuses to move. Quote Link to comment Share on other sites More sharing options...
