Banshee one cylinder not firing
Hello everyone hope all is well!
I have a 2004 350cc banshee motor full stock(other than stator it is aftermarket)
So basically, I just recently(today)changed the flywheel/stator. Before i changed it one cylin was giving more spark than the other. Now they both throw the same spark.
But, one cylinder isn’t firing, it releases pressure(similar to a gust of wind) but isn’t firing. When I turn on the bike one cylin fires in which it becomes warm, but the other side doesn’t. What could it be?
PS: My thoughts are it could be the carb or reed. Because when I first put the new flywheel/stator and started it both cylinders were firing(assuming by the sound) but when I turned it off after about 10-30 min I went to start it back, when one cylinder started to not fire again.
