Panic305 Posted February 24 Report Posted February 24 Need some help with jetting 392 stock stroke, cool head 21cc domes pwk28s oem stator and cdi 1200ft elevation Quote
JKJK Posted February 24 Report Posted February 24 Assuming temp around 60deg.160 mains,48 pilots.jjh needles middle clip.should be safe+ have to lean down from there. Quote
Panic305 Posted February 27 Author Report Posted February 27 I ended up on 155 main and 45 pilot , jjh on the middle clip. running a lot better but still gurgling in the mid range before hitting the powerband then it just takes off will play around with the needle position to see if it clears out Quote
