Louis Posted February 3 Report Share Posted February 3 I painted the frame on my Yamaha banshee so I took everything apart, when I put it together I started it and it instantly sores to full throttle. It ran perfect before I took it apart I really doubt it’s a vacuum leak maybe I screwed up something with the wiring like a ground but I doubt that too. It’s also not the throttle slides their in the correct position and don’t get stuck. What should I check next? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted February 3 Report Share Posted February 3 If your slides are all the way down, do a leak down test. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 4 Report Share Posted February 4 forgetting the choke cross over hose can cause that. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted February 4 Report Share Posted February 4 I wondered if that would...usually it wont start 2 find out Quote Link to comment Share on other sites More sharing options...
Louis Posted February 10 Author Report Share Posted February 10 The slides weren’t adjusted properly that’s what caused the idle issue but now the quad kicks back at me hard when I try to start it. did I screw up the wiring? The timing is at 0 and the carbs are in sink so maybe it’s a ground causing this the only ground that I messed with is the one on the voltage regulator some help would be great. Quote Link to comment Share on other sites More sharing options...
Louis Posted February 10 Author Report Share Posted February 10 On 2/4/2024 at 12:19 PM, 375hp banshees said: I wondered if that would...usually it wont start 2 find out Yeah it connected Quote Link to comment Share on other sites More sharing options...
