locogato11283 Posted January 20 Report Share Posted January 20 Redline Racing 24DM FOR SALE!! 78mm bore. Lightened Mattoon cases. New stator and flywheel. Stock trans with billet 2nd gear. 8 plate clutch. Lightened Mattoon clutch cover. Chariot stator cover. 48mm Lectrons. KRP pipes. Pistons and domes are fresh. Transmission looks good. Crank looks good. Fork window has been JD Weld epoxied up. Motor was dropped in shipping once and it slightly bent the area around the fork window. No issue other than I couldn't get it to stop dripping oil all the time. I got tired of fucking with it and sealed it up. I'm sure you could grind it off and use it but I never did. Cost to build all this junk new is nearing $20,000. Roughly 180HP/100TQ with this setup. $13,000 picked up for motor, pipes and carbs. For $20,000, I will put it in the stock chassis bike with the Snipers. Pics of everything below. Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted January 24 Report Share Posted January 24 Mannnnn, I'd go $12k for the motor in the stock frame roller. Quote Link to comment Share on other sites More sharing options...
registered user Posted January 25 Report Share Posted January 25 stop playin bruh. u aint got 12G Quote Link to comment Share on other sites More sharing options...
