Machoman Posted November 14, 2023 Report Share Posted November 14, 2023 Got these off amazon but no info on bolt size.. so I was wondering if you guys know the specs for them! Thanks https://www.amazon.com/Bracket-Banshee-1987-2006-2GU-21513-00-00-2GU-21514-00-00/dp/B09CNP62J9 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 14, 2023 Report Share Posted November 14, 2023 Bracket to frame is a flange head bolt 6x1.0 x 10mm, bracket to fender is a pan head screw 6x1.0 x 16mm with a nylock nut. I bought the cheapest ones I could find once too, threw them away and bought OEM. Quote Link to comment Share on other sites More sharing options...
Machoman Posted November 14, 2023 Author Report Share Posted November 14, 2023 Yikes lol uk maybe I will just return and get oem. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Machoman Posted November 14, 2023 Author Report Share Posted November 14, 2023 Bracket to frame is a flange head bolt 6x1.0 x 10mm, bracket to fender is a pan head screw 6x1.0 x 16mm with a nylock nut. I bought the cheapest ones I could find once too, threw them away and bought OEM. Which oem part is it exactly? I seen a couple fender stays on the diagram lolSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 14, 2023 Report Share Posted November 14, 2023 6 minutes ago, Machoman said: Which oem part is it exactly? I seen a couple fender stays on the diagram lol Sent from my iPhone using Tapatalk There the tubular ones and the flat "L" shaped ones, left and right each. 1 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 14, 2023 Report Share Posted November 14, 2023 2GU-21513-00-00 STAY, FENDER 1 and 2GU-21514-00-00 STAY, FENDER 2 1 Quote Link to comment Share on other sites More sharing options...
Machoman Posted November 14, 2023 Author Report Share Posted November 14, 2023 2GU-21513-00-00 STAY, FENDER 1 and 2GU-21514-00-00 STAY, FENDER 2 Appreciate the help, so double up on those and they will support the front fender plastics and keep them from flopping? Lol also i was checking on my frame where the brackets would go and seems like theres no thread in there so im assuming i may have to tap it..Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 14, 2023 Report Share Posted November 14, 2023 You should already have the "L" ones, they hold the radiator too. The holes are threaded from the factory. But who knows what happens in 25+ years to one. Quote Link to comment Share on other sites More sharing options...
Machoman Posted November 14, 2023 Author Report Share Posted November 14, 2023 Yeah I see the mini l ones.. just not the long tube one. Idk i looked inside the 2 holes on frame and they look smooth as heck no threading. Its a 2002 i just got it about a week ago and basically upgraded everything. I even had to retap the footpeg because the guy i got it from stripped it lolSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 14, 2023 Report Share Posted November 14, 2023 Not the two holes. should have a square stand off lower on the frame. Quote Link to comment Share on other sites More sharing options...
Machoman Posted November 14, 2023 Author Report Share Posted November 14, 2023 Ahhh yes. Lol ok so thats where the brackets will be installed. Nice. Im going to replace my reeds also.. got the V-force 4Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Machoman Posted November 15, 2023 Author Report Share Posted November 15, 2023 So whoever painted this frame it looks like they went over the lower hole for mounting…Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
