What All Do I Gotta Do To Ship A Complete Motor?
Last time I shipped a engine, I got a old sturdy pallet and cut it up. I bungeed the motor down to the cut pallet in several places and built a box around the pallet base with plywood.
Best thing to do, go buy yourself some of that liquid foam insulation stuff that starts out as a liquid and foams up. Tape up the bottom of the box along all open edges, put some foam in for a base and let it foam up a bit. Put your engine in a plastic bag and make sure that is completely sealed shut with tape, and then pour in the rest of the foam and let it foam up out of the box some, cut it so you can close the box and you'll be good to go.
all great ideas so far.ply wood bottom drill a couple holes. wire it down.if you can find a box sturdy enough.do what abyss said the foam is a good idea. i usually build a crate.wire it down tight to the bottom piece of plywood, put 2 2x4 runners on the bottom then build the crate around it using plywood and 2x4`s.i just shipped a cr 125 motor usps. i put it in a milk crate wired it up tight ,then built around the crate with plywood, screwing the wood into the crate.it was tight as could be. then shrink wrapped it.
  • 4 weeks later...
