thebadshee Posted December 31, 2003 Report Share Posted December 31, 2003 i have a 2001 banshee my 35mm pwks dont open all the way only about 3\4 throttle what am i doing wrong and does anyone else have this prob or know of a fix thanks Quote Link to comment Share on other sites More sharing options...
NYUK Posted December 31, 2003 Report Share Posted December 31, 2003 you may have to ad a spacer above the adjustment on the top of the carb.like an old pair of the brass adjusters,cut them to size till you get the slides to open all the way.if your adjusted all the way now.you will probably have to add a spacer. Quote Link to comment Share on other sites More sharing options...
PassionRE Posted January 3, 2004 Report Share Posted January 3, 2004 Your cable coupling tube built into the cable doesn't have enough travel for those carbs. You will have to replace the cable assembly with one designed for those carbs..Jim Quote Link to comment Share on other sites More sharing options...
