Shee Aint Movin
i posted a while back about me foulin plug and what i need to do well yesturday i tired something new i dont run a air box ando have a uni filters and i put the skins on it i put the oil stuff on te skin that is why i though it was foulin plugs but it just wasnt gettin enough air flow while anyways i road today and it did fine all day no problems i brang it home and and let it sit for about 3 to 4 hours then was gonna go put it up and it would not start i though it was a plug so i put 2 new ones in and nothin happen i still dont think its gettin enough gas i need some help this thing is startin to piss me off
hahah superchicken your a real hardcore badass B) but who would have known that it would just run one side with that gas why would it even start but neways its not gettin enough air to pull gas through or some shit do you think it could be the jettin and if so which one the pilot or main do i need to go up size or down. thanks superchicken
any way back on subject,wizard u shouldent have to adjust your main or pilots in one carb,and not the other.if the case is that one cylinder isnt firing because of lack of fuel there is a problem or two.
1=if its the right side carb maybe the choke tube is
off.
2=possible air leak in the intake-reed cage-boostbottle
the next time you get it running spray some wd-40 around the carb and intake thats not firing and if its leaking youll notice a change of idle speed. sorry for the attitude i broke my wirst last night and im rollin on percs
