Amstaff Posted December 31, 2003 Report Share Posted December 31, 2003 how often should you change you wheel bearing axel bearings and a arm bushings and so forth?is there a average of how long they last i ride trails and strip mines there was alot of mud this yr so i dono if that comes into play or not? Quote Link to comment Share on other sites More sharing options...
spoin39 Posted December 31, 2003 Report Share Posted December 31, 2003 Usually when you notice too much play. Move the f.wheels back/forth, A-arms in/out, and so on, if there is noticeable freeplay, replace them. I use the needle bearings in my A-arms and like them better than the bushings. Quote Link to comment Share on other sites More sharing options...
Holyman Posted December 31, 2003 Report Share Posted December 31, 2003 Don't change 'em until you need to. If you need A arm bearings or swingarm bearings, let me know. I give BHQ members a break from the eBay prices email me... IHRbearings@peoplepc.com Quote Link to comment Share on other sites More sharing options...
BenBB Posted December 31, 2003 Report Share Posted December 31, 2003 In 3 years I've only replaced my rear axle bearings once. I repacked the fronts about a year ago and just keep the a-arm bushings greased (like after every weekend that I ride I wash then grease it). If you're in alot of mud I would check the rear bearings like spoin39 said, and if/when you have to replace them put a grease zerk on the carrier, and remove the inner bearing seals so grease will get to them. They will last alot longer if you can get grease to them and force any water out.... Quote Link to comment Share on other sites More sharing options...
spoin39 Posted December 31, 2003 Report Share Posted December 31, 2003 BenBB has a good point, I have had a RPM carrier for so long I forgot the stock one isn't greaseable. Quote Link to comment Share on other sites More sharing options...
Amstaff Posted January 1, 2004 Author Report Share Posted January 1, 2004 good lookin out thanx! Quote Link to comment Share on other sites More sharing options...
