I know the mains won’t work with my PWK 28mm carbs, I believe pilots are the same,  but will the needle  work ?
my 48 pilot is good, the air screw and idle are sweet.
my needle is one clip down from top. I was trying to lean it out to get rid of my midrange bog. Before I move another clip up, would I be better of going with Toomeys perfect kit  ?  Terrible bog between shifts and the powerband is weak.
Would adjusting the mains help at all with said bog ?
6 hours ago, hoppedupandcutdown said:
Toomeys perfect jet kit is made for factory Mikuni carbs, of which no parts interchange with the Keihin PWK
I reached out to Toomey.
-  they said exactly that.
