pullzatrigger Posted April 8, 2023 Report Share Posted April 8, 2023 My 01 banshee has a dc conversion kit. When the key is on i have lights but no spark. When the key is off i can start it but lights wont work. Do i need to rewire my key? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 8, 2023 Report Share Posted April 8, 2023 Did it Work before ? how did you wire in the DC conversion? Quote Link to comment Share on other sites More sharing options...
pullzatrigger Posted April 10, 2023 Author Report Share Posted April 10, 2023 I got my dc harness from south texas banshee. Lights are wired in appropriately. The key is just a run of the mill ebay buy. I might try a key delete On 4/8/2023 at 6:44 AM, 375hp banshees said: Did it Work before ? how did you wire in the DC conversion? I got my dc harness from south texas banshee. Lights are wired in appropriately. The key is just a run of the mill ebay buy. I might try a key delete. Its just puzzling. Quote Link to comment Share on other sites More sharing options...
pullzatrigger Posted April 10, 2023 Author Report Share Posted April 10, 2023 On 4/8/2023 at 6:44 AM, 375hp banshees said: Did it Work before ? how did you wire in the DC conversion? And it work prior to my dc conversion. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 10, 2023 Report Share Posted April 10, 2023 6 hours ago, pullzatrigger said: I got my dc harness from south texas banshee. Lights are wired in appropriately. The key is just a run of the mill ebay buy. I might try a key delete I got my dc harness from south texas banshee. Lights are wired in appropriately. The key is just a run of the mill ebay buy. I might try a key delete. Its just puzzling. iirc, the key is N/O & grounds to kill. Might wanna ohm coil ground to frame... key on n off & same w/ cdi kill wire. To see what switch is grounding... ill bet ebay sw is N/C & wired in differently than factory, & stb's harness is factory based. Quote Link to comment Share on other sites More sharing options...
pullzatrigger Posted April 14, 2023 Author Report Share Posted April 14, 2023 On 4/10/2023 at 6:00 AM, 375hp banshees said: iirc, the key is N/O & grounds to kill. Might wanna ohm coil ground to frame... key on n off & same w/ cdi kill wire. To see what switch is grounding... ill bet ebay sw is N/C & wired in differently than factory, & stb's harness is factory based. I think you're right i jumped the kill wire and now i have spark all the time and key will only work lights. Which im fine with... thanks guys. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 15, 2023 Report Share Posted April 15, 2023 Guys? aint nunuh deez lazy fuq's helped 2 Quote Link to comment Share on other sites More sharing options...
