BansheeRus Posted April 6, 2023 Report Posted April 6, 2023 I have a 2001 banshee with fmf pipes and exhaust 280 main jets and 25 pilots she runs like a beast and idles forever passed the leak down test and both Coldplay’s are set right but whenever I try to wheelie it bogs or floods out it runs perfect on 4 wheels but terrible on 2 any suggestions on what it could be like I said runs great and idles but floods out when wheelie thanks and advice is appreciated Quote
dano3 Posted April 6, 2023 Report Posted April 6, 2023 Check and adjust your carb float height. I would check your floats (fuel can leak into them)/ float needle valves/seats too before you make adjustments in case they are worn out. 1 Quote
BansheeRus Posted April 7, 2023 Author Report Posted April 7, 2023 On 4/6/2023 at 11:04 AM, dano3 said: Check and adjust your carb float height. I would check your floats (fuel can leak into them)/ float needle valves/seats too before you make adjustments in case they are worn out. Thanks for replying float heights are set at 21 each and carbs have a brand new rebuild kits with 289 main jets and 27.5 pilots running find pipes been driving me crazy trying to figure this out Quote
