As a ballpark figure, how much does my modified '96 make? (mods listed below)
I just inherited an excellent condition '96 Banshee, but I didn't build it. I'll list the mods I'm sure that have been done, and since I don't have access to a dyno, I'm hoping someone can give me a ballpark HP figure based on these mods/hardware: It has Toomey T5's and silencers, nearly perfect cylinder compression, an aftermarket timing plate, the standard Toomey airbox vent mods, carb throats 1.5mm over stock diameter, and jetting done for anywhere between sea level and 2500 feet. The displacement is stock, but it has a fairly aggressive port/polish job on the exhaust side, and aftermarket reed valves (I think it might be a 4-reed setup, but I'm not sure), as I'm not much of a mechanic. Knowing mine is a '96 and had about 47HP stock (not 34 like the post-2000 models), what kind of estimate would you give on its likely HP output range?
