Bigscott260 Posted February 20, 2023 Report Posted February 20, 2023 2003 yfz350LE - cool head - Toomey t-5’a - vito’s reeds - Vito’s billet intake - 28mm PWK’s - Uni pods air screw half turn out, really rich air screw one turn, idles to the moon, idle adjustment does nothing air screw 1.5 turns out, really lean, idles to the moon, idle adjustment does nothing. Stock PWK 135 main / 38 slow should I start with checking for leaks? (installed the intake/reed gaskets dry). Take them apart and reassemble with some yamabond? the bog and oil smelling smoke tells me it’s rich, correct? Do I downsize the main to allow for less fuel, and adjust the airscrew again ? I thought with the air pods I would be running lean and would need to upsize the main ? As for test riding, she’s currently staying warm in the basement for winter…. - and yes, I’ve searched and read all the forum topics already. Quote
locogato11283 Posted February 22, 2023 Report Posted February 22, 2023 Whoa whoa whoa. Those are not even close to the right jets. Do not ride it. Start with 165 main and 52 pilot. Quote
Bigscott260 Posted February 26, 2023 Author Report Posted February 26, 2023 Thanks. I’ve got two jet kits on the way and I’ve taken the intake apart and reassembled using some yamabond4 with the gaskets. Quote
Bigscott260 Posted February 26, 2023 Author Report Posted February 26, 2023 I opened up the brand new PWK 28mm carbs today. Catalog said 135 main and 38 slow…..actual 115 / 34. I’ll start with the 165 a 52. Quote
locogato11283 Posted February 27, 2023 Report Posted February 27, 2023 I opened up the brand new PWK 28mm carbs today. Catalog said 135 main and 38 slow…..actual 115 / 34. I’ll start with the 165 a 52.That might be what it comes with but that’s not what the motor will need. Quote
Bigscott260 Posted February 27, 2023 Author Report Posted February 27, 2023 Definitely not what the engine needs..lol. I bought them from who else…Vito’s. Quote
375hp banshees Posted February 28, 2023 Report Posted February 28, 2023 Sorry to hear that...good luck Quote
Bigscott260 Posted March 5, 2023 Author Report Posted March 5, 2023 Definitely gotta stop smoking grass while working on my ‘Shee ! Installed the 165/52 jets still couldn’t get a decent high idle, figured I’d try a #50 pilot, took the carbs apart…..again….wouldn’t you know it, I never put the main jet in one carb and the slow jet wasn’t threaded in !! WTF ?!?!! after smokin some more grass I’m happy too say everything is back together and running awesome. As awesome as I can get without riding her. Thrilled to say the least, and definitely learned a lot about carb adjustment the last couple of weeks. Quote
375hp banshees Posted March 6, 2023 Report Posted March 6, 2023 Da fuq you wait'n on. fire up another un & take'r for a spin Quote
375hp banshees Posted March 6, 2023 Report Posted March 6, 2023 Grass,snow, banshees @ClaudeMachining 1 Quote
Bigscott260 Posted April 23, 2023 Author Report Posted April 23, 2023 I’ve since got the Shee outside, with a 165 main , 48 pilot and the needle set on second clip from top. Airscrew 1-1/2 turns, idle set, and carbs synced. still have a terrible bog midrange between gears and the powerband is nowhere close to as powerful as before I added some goodies. I’m not sure what needle it has, are there other needles I need to be looking for/at or maybe just drop it another clip ? im also running 100 octane LL with 21cc domes. Quote
