Metal_man_Rob Posted January 29, 2023 Report Share Posted January 29, 2023 There are a million threads on case sealing. Too many contradict eachother. For case halves, I plan on yamabond 4. I see that some people use threebond 1211, 1184 and 1215. Some people put sealer around the crank and trans seals as well as the key on primary and water pump gear. Kevin at STB also uses sealer around seals. I also always use sealers on base gaskets and intake gaskets. So, for those of you truly experienced with building: Do you use the same sealer for everything or prefer different sealers depending on what you're sealing on the banshee engine? What do you use and where? Thanks, in advance. Sent from my SM-S908U using Tapatalk Quote Link to comment Share on other sites More sharing options...
caleb90 Posted January 30, 2023 Report Share Posted January 30, 2023 Yamabond 4. Sealant on reed gaskets, clutch and water pump gaskets. Unless there are blemishes on the cases where the crank and tranny seals go i wouldnt put sealant on those, just a high temp grease 1 Quote Link to comment Share on other sites More sharing options...
SKEETER Posted January 30, 2023 Report Share Posted January 30, 2023 Cant beat OG jb weld. Holds great. Quote Link to comment Share on other sites More sharing options...
Metal_man_Rob Posted January 30, 2023 Author Report Share Posted January 30, 2023 Cant beat OG jb weld. Holds great. Ohhh you sombitch!Sent from my SM-S908U using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted January 30, 2023 Report Share Posted January 30, 2023 I use grease on paper gasketts. I use liquid gasketts ( compatible with fuel) on steel gaskett and steel/aluminium surface.I put grease on inner lips of seals and nothing around (must be clean and free of grease).I use permatex motorseal or 1211 or 1184, yamabond, hondabond, all the same thing.Envoyé de mon SM-S908W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 30, 2023 Report Share Posted January 30, 2023 I have never used sealer on anything but the case halves. Quote Link to comment Share on other sites More sharing options...
Metal_man_Rob Posted January 30, 2023 Author Report Share Posted January 30, 2023 I use grease on paper gasketts. I use liquid gasketts ( compatible with fuel) on steel gaskett and steel/aluminium surface.I put grease on inner lips of seals and nothing around (must be clean and free of grease).I use permatex motorseal or 1211 or 1184, yamabond, hondabond, all the same thing.Envoyé de mon SM-S908W en utilisant TapatalkThanksSent from my SM-S908U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Metal_man_Rob Posted January 30, 2023 Author Report Share Posted January 30, 2023 I have never used sealer on anything but the case halves.Right onSent from my SM-S908U using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted January 30, 2023 Report Share Posted January 30, 2023 49 minutes ago, locogato11283 said: I have never used sealer on anything but the case halves. Typicaly, banshee base gaskett are always paper. On smaller one cylinder setup, we often have metal base gaskett, thus the use of liquid gaskett on them. 1 Quote Link to comment Share on other sites More sharing options...
kawa110 Posted January 30, 2023 Report Share Posted January 30, 2023 Use sealer on metal mating surfaces such as shee cases. Paper gaskets for cylinder base and side covers. I don’t grease. Seen people grease paper gaskets to make removal easy and reusable. I don’t I replace them. Made plenty of paper gaskets from soda and beer box cardboard over the years. Seen metal gaskets for heads…either a “crush” style or copper plate/copper washers…no sealer. In a pinch I’ve taken the copper gaskets heated them until they “glow” and reused as long as they weren’t cracked or brittle. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Metal_man_Rob Posted January 30, 2023 Author Report Share Posted January 30, 2023 Use sealer on metal mating surfaces such as shee cases. Paper gaskets for cylinder base and side covers. I don’t grease. Seen people grease paper gaskets to make removal easy and reusable. I don’t I replace them. Made plenty of paper gaskets from soda and beer box cardboard over the years. Seen metal gaskets for heads…either a “crush” style or copper plate/copper washers…no sealer. In a pinch I’ve taken the copper gaskets heated them until they “glow” and reused as long as they weren’t cracked or brittle. Sent from my iPhone using TapatalkYeah I don't use anything on the side cover gaskets. I use the copper stuff on the metal gaskets on the LT80s but I have O rings for the banshee head.Sent from my SM-S908U using Tapatalk Quote Link to comment Share on other sites More sharing options...
caleb90 Posted January 30, 2023 Report Share Posted January 30, 2023 4 hours ago, locogato11283 said: I have never used sealer on anything but the case halves. You work on your motors? Quote Link to comment Share on other sites More sharing options...
kawa110 Posted January 30, 2023 Report Share Posted January 30, 2023 Use grease to “hold” the o rings on head if needed. I’ve never used the copper spray. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
caleb90 Posted January 31, 2023 Report Share Posted January 31, 2023 16 minutes ago, kawa110 said: Use grease to “hold” the o rings on head if needed. I’ve never used the copper spray. Sent from my iPhone using Tapatalk This ^ copper coat is for working on old ass tractors ,trucks, lawn mowers ect. Just like idian head shelack Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 31, 2023 Report Share Posted January 31, 2023 2 hours ago, caleb90 said: You work on your motors? Shipping a 24DM is expensive. Quote Link to comment Share on other sites More sharing options...
